BAT Export
dave.hodgkiss
Can i run any OS admin commands to provide me with the same output as BAT would give? For Example
BAT Export:
Device
Device Profiles
Line Groups
Hunt Pilots
Can i also run an OS query to give me a list of actively logged in profiles?
Is it possible to log a device profile into a phone from OS Admin. I need to log several device profiles in at once, can it be scripted?
Cheers
Dave
Leonardo Santana
Hello Dave,
You can export this CUCM config depending on your CUCM Version.
To see who is logged, go to Device -> Phone, on related links select the option "Active logged in device report", there you can find the active logged device profiles.
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
Hi Leonardo,
I'm well aware of how to display actively logged in device report in CUCM i need to export that data, which isn't possible from CUCM. Do you know of a way of extracting it?
Dave
