BAT failed to update primary user device
I'm trying to do a BAT on cucmbe 7.0.1-11000-2.
It's synced with the ldap. When i'm trying to update the "primary user device" field, nothing happened, other fields such as mobility and MVA enable/disable is ok.
The job scheduler reported a success.
Just wondering anyone faced the same issue?
Luckily in this implementation, i only have 12 mobility users which i can set them manually.
Hall of Fame Super Red
Re: BAT failed to update primary user device
Hi Kin,
It sounds like this bug;
CSCsr14381 Bug Details
cannot update device assoication if "Primary User Device" was configured
Symptom:
CUCM 6.1.2. Tried to use BAT to update device association on end user page. BAT job completed successfully, but "device association" was not updated.
Conditions:
1) CUCM 6.1.2
2) On CCMAdmin > User Management > End User, configure a "Primary User Device"
3) Use BAT to update this user's "Controlled Device". The desired device name is the same as in step 2)
4) BAT job completed successfully. But device association was not updated.
Workaround:
Set "Primary User Device" to none.
Status
Fixed
Severity
3 - moderate
Last Modified
In Last Year
Product
Cisco Unified Communications Manager (CallManager)
Technology
1st Found-In
6.1(2)
Fixed-In
6.1(2.9901.109)
7.1(0.39000.8)
6.1(2.1110.1)
7.0(0.66666.1)
7.0(0.66666.2)
7.1(0.98999.7)
7.0(1.12003.1)
7.0(1.12003.2
Hope this helps!
Rob
Rob, i saw this bug when i search through this forum but mine is a little different as describe in the symptom.
I have the controlled device configured, mobility and MVA enabled while the primary user device "refused" to get updated.
No matter what i try, such as having a bat with only userid and primary user device field, disable both mobility/MVA first before updating the primary user device.
or i should set both primary user device and controlled device into none first and update them again together?
436
