BAT for Abbreviated Dials
Hi guys
Is possible insert Abbreviated-Dial using BAT or another tool?
Best Regards
1 ACCEPTED SOLUTION
Re: BAT for Abbreviated Dials
You can bulk update phones and assign speed dials. You go to Bulk Administration>phones>update phones. Scroll down to speed dials and pick a phone template from the drop down list. Then choose edit speed dials option next to the drop down list.
This would associate the same list of speed dials to all phones returned by your query or identified in your custom file. If you want to use bat to add unique speed dials per phone, then you would need to bulk insert the phone with the "all details" option.
Note: speed dials and abbreviated dials are essentially the same thing.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
1 REPLY
Bill
521
