Community Member
BAT for Gateway Configuration
Hi ,
I am trying to import gateway configuration (MGCP) via BAT
Previous post i reffered to was
https://supportforums.cisco.com/document/144461/how-migrate-h323mgcp-gateway-configuration-across-router-models-bulk#comment-9938346
It was helpful to get me to upload.
Its not clear what extra commas i need to remove..
Upload was completed.
Job schedule was completed too.
But changes is not reflected. (i just changed the description of gateway)
In Job logs i get the below message: MGCP Slot java.lang.NullPointerException
1 REPLY
 Can you check are there are
Can you check are there are several "Commas" after each of the lines; what you need to do remove all the additional commas by opening this using wordpad or notepad++ .
Br,
Nadeem
Br, Nadeem Please rate all useful post.
415
