11-23-2009 09:08 AM - edited 03-15-2019 08:33 PM
I am trying to import phones with users option in BAT for 7965 models.does phone template field in csv file is the template that we create for 7965 sccp under BAT tools/phones/ phone template ?
thanks
sgeorge
Solved! Go to Solution.
11-23-2009 11:28 AM
It will be the name for Phone Template that you created in CCM Bulk Administration>> Phones >> Phones Template.
There is a name for 7965 Template that you created.
11-23-2009 09:21 AM
NO you need to create or use one file format
Bulk Administration >> Phones >> Phones File Format
or
Bulk Administration >> Phones & Users >> Phones & Users Format
11-23-2009 10:14 AM
hI,
Thanks for the reply. In the bat.xlt file, there is a mandatory column "Phone Template" (string 50 Manadatory), what name goes to that field? does phone button template goes to that field?
thx
11-23-2009 11:28 AM
