BAT Shared Directory Number Question
Can BAT be used to add phones that share a Directory Number, or to add the same directory number to multiple phones?
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: BAT Shared Directory Number Question
keep in mind though that all settings will be overwritten so make sure you reference proper alerting name, etc.
Bronze
Yes,you can use BAT to add phones with shared lines.
Gnan.
186
