11-01-2010 08:49 PM - edited 03-16-2019 01:41 AM
Hello Experts,
I need to BAT/TAPS 400 7925 Wireless phones. I have exported the detailed 7925 template but am not able to import and TAP them into the CallManager. I am using CM 7.1.3. Could you please kindly share your experience and help me out?
MK
11-01-2010 09:22 PM
I have imported lots of 7925s onto 7.1(3). What exactly isn't working? Note that I do it slightly differently: I don't export the template. I create the template and then do the import against it with only those fields (e.g. MAC, Description, Owner User ID, Mobility User ID, DN, etc).
11-01-2010 09:35 PM
Jonathan,
Thank you for your prompt reply. The problem is that I don't have the Mac Address and I want to BAT them in first and TAP them after. Would that be possible that I can use your template? Would you mind sharing it with me?
MK
11-02-2010 05:49 AM
Can anybody please help?
MK
11-02-2010 06:02 AM
CUCM ships with an Excel document template in the BAT Upload/Download folders directory; just use that. Select only the columns that will change per record, check the Dummy MAC Address box, and export the file. Upload it to BAT, create a device template, and insert the record against that template. Don't forget to check the "Create Dummy MAC Address" box during insert.
11-02-2010 06:06 AM
What is the name of the template. I don't seem to be able to locate it? Will I be able to TAP them in after importing them?
MK
11-02-2010 06:17 AM
I don't see why not as long as you use dummy MAC addresses. We do not use TAPS so I can't promise that part.
11-02-2010 06:22 AM
Do you know what the name of the template is?
MK
