BAT & TAPS on CUCM8.5
We have a customer who has a CUCM 8.5 and a Siemens PBX that have a trunk between them. They are slowly migrating to the CUCM using the BAT and TAPS with dummy MAC addresses. The file is uploaded one day and the user TAPS in the next day to register their phone and DN.
Scenerio:
Siemens user extn 2000 is migrating over the CUCM on DN 2000.
(Before the user TAPS) If I upload the BAT file will the CUCM pass any incoming calls for that DN to the Siemens or play a CUCM Number Unreachable message? ie is CUCM clever enough to recognise that that user has not registered yet and pass the call over the trunk?
Cheers
Rich
Everyone's tags (3)
1 ACCEPTED SOLUTION
I haven't tested this, but I would assume that since the DN is already in the dnorpattern table as a routable DN, it would try to reach it. Unless you have a specific RP with the exact same DN and with the partition of such RP above the one from the line DN in the CSSs, then, you would reach the phone on Siemens.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
java
java
Thanks Java. If I put the DN in a 'Holding Partition' so I can add them without affecting the Siemens phone- is there a way to bulk change the Partition if I have lots of these?
Yeah, you can use BAT and the update lines option.
java
java
And similiarly if I use the BAT file to update partition (if DNs are easily selectable eg consecutive)?
200
