11-13-2008 08:09 PM - edited 03-15-2019 02:32 PM
hi guys
any one has a BAT tamplate for addin users into CCM 4.x
thanks in advance
11-14-2008 07:10 AM
11-14-2008 04:03 PM
hi Rob
thanks for your quick respons :)
i am using this one but the thing is with CCM 4 when i am trying to add user+phone
the user is added but with the phone i am getting the following error !!
Failure Details : See the release notes if any Error Message is not clear.
MAC Address Error Code Error Description
02004C4F4F50(line 1) 438 object doesn 't support this property or method
thnks anyway for your help
11-14-2008 05:20 PM
Can you post your file?
What is the phone model?
Chris
11-14-2008 11:03 PM
11-15-2008 07:51 AM
I belive you are missing the number of lines indicator, which I belive is required in BAT for CM 4.1, i.e:
user1,lastname,userid,12345,,sales,12345,,,1,02004C4F4F50,SEP02004C4F4F50,,2323,batDis,batline,,,,,
It would be useful to see your file with headers.
Chris
11-15-2008 10:08 AM
Hi Marwan,
Here is an example of a .csv for adding a Phone/User and a 7941 from a 4.x BAT
Don,Ferguson,dferguson,,,Enrollment Services,,,,001B0CAD4B23,B156-02 - Don Ferguson,,6000,Don Ferguson,,,,,,
I do think that Chris is onto something with his reference to the Lines portion of the setup. Make sure that the Template that you configured for these additions has the proper Line info (it's kind of a secondary step in the Add Template) Then when doing the actual BAT .xlt make sure to check the matching number of Lines checkbox before saving.
Hope this helps!
Rob
