BAT UDP services issue
Hi all,
I am currently importing around 35 users using a BAT file I have created. Everything goes in fine and the users details are all present and correct, except the services wont assign. If I do one at a time using the same method the services go in no problem. If I try and do them all they wont take affect. Any ideas?
1 REPLY
Re: BAT UDP services issue
I solved my own issue after having a read of the Cisco documentation.
If you disable the TFTP service then import all the services come down and everything goes through as it should.
Hope this helps someone in the future
99
