Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
BAT - updating phone
I trying to update all my phons with new external mass; line text display.   its different for everyphone.
1. i did a phone export with the list of phone I wanted to change.
2. made my chaned to the excel file
uploaded to ccm using bat; phone; update phones
then I run the update phone nothing happen.
what am I missing?
where can I got to see why is failing?
thanks
under Buld Administration --> Job Scheular --> press find, get the update job you have done, open it and see if there is any error message.
When you do the update there is an option to overwrite existing settings it is very important to check those boxes otherwise nothing will happen.
Voice CCIE #37771
Make template for specific phone.
Update .txt or .csv file with approriate data
Add/Update line
I used that option for one phone.  it worked but it will overright eveything on the line.  I do not want to overright some of the setting on the line, only the line text; external number mass.
Hi Derrik.
Have you tryed update lines option under Bulk Administration Tool?
BulkAdministration --> Phones --> Add/Update Lines--->> Update Lines
Here you can search for directory numbers you want to modify.
Than check only the radio button next to the option you want to change.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
112
