BAT user update
Hi All,
I am using CUCM 7.0. I have updated user pin with BAT. when I try to login with username with PIN, it says "[209]-Change PIN". any idea would be appreciated?
alex
  • IP Telephony
1 REPLY
Re: BAT user update
Hi!
Please check this bug: CSCsl76193
Can you check the value for "user must change at next login" for enduser PIN
from User->Credential Policy Default page?
Do not use the option for "User Must Change at Next Login"
Hope this helps!
Teresa.
Regards, Tere. If you find this post helpful, please rate! :)
169
