BAT with IP Address Autodetection URL field
I need to update several hundred IP Communicators with a new address in the field "IP Address Autodetection URL". I am using Call Manager 4.13 with BAT version 5.14c.
BAT doesn't allow you to change the "IP Address Autodetection URL"
How can I update all of these IP Communicators in bulk? Query in SQL??
1 REPLY
Bronze
Re: BAT with IP Address Autodetection URL field
Use CCMAdmin to update Cisco IP Communicator fields such as:
LDAP Server Information File
RTP Port Range Start
RTP Port Range End
Verify Software Versions
CSCed77567: check this bug for more information
116
