BAT.XLT
I'd like to use the BAT.XLT file to populate a MCCP VG224 gateway. The BAT.XLT file I have doesn't support this. We're running BAT 5.1(4R). Basically, the MAC address for each gateway port is 15 characters and BAT only allows 12. Is there a more recent version of BAT.XLT that I can download that would work with this version of BAT?
Hall of Fame Super Red
Re: BAT.XLT
Hi Frank,
You won't love this one :(
The version of BAT you are using does not support adding the VG224 :(
CSCeg88823
Symptom:
BAT does not support adding VG224 ports in bulk
Conditions:
This is for all version of BAT and all current version of Callmanager 3.x, 4.x, 5.x up until 6.0.1
Here is an example of what the .csv does look like in BAT 6.0.1 for the VG224
The following sample format shows the required field length and string types followed by sample of CSV files for a Cisco VG224 gateway.
MGCP Domain Name(Mandatory, 1 to 64 characters),Description(Optional, up to 100 characters),Slot(Mandatory, up to 3 numerals), Subunit (Mandatory, up to 3 numerals), Port Number(Mandatory, up to 3 numerals), Port Description Optional, up to 50 characters),Port Directory Number(Optional, up to 24 numerals and special characters)
Sample
MGCPTest,VG224 Lab Gateway,2,0,0,Port 0,97255576601
MGCPTest,VG224 Lab Gateway,2,0,1,Port 1,97255572001
Cisco Unified Communications Manager Bulk Administration Guide 6.0(1)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/6_0_1/t18csvap.html#wpxref17978
Hope this helps!
Rob
Re: BAT.XLT
Thanks Rob. With a bunch of dorm rooms all running analog via the VG224, this is indeed sad news. Maybe I can leverage it to justify an upgrade.
413
