BAT
Hi All,
I am trying to install BAT plugin in CCM 4.2(1)sr1b but message is comming "would you like to reinstall 5.2(1b)" in Publisher.
I just wanted to confirm should I go ahead with this so as to avoid any problem in future in Publisher.
Also, is there any way to find which BAT version is presently installed in CCM?
regds,
aman
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: BAT
Hi Aman,
This version of BAT is supported with CCM 4.2(1) so you should be "good to go". Here is the Matrix;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_software_versions_comparison.html
Here is how to find the current version that is installed;
Finding the BAT Version
To find the current version of BAT, choose Help > About Bulk Administration Tool > Details.
To find the current version of BAT from Cisco CallManager Administration, choose Help > Component Versions.
If BAT is not currently installed, you can find the version of BAT that is available with Cisco CallManager without installing it. To do this
Step 1 Download the BAT application from the Cisco CallManager Install Plugins window.
Step 2 Right-click the file BulkAdministrationTool.exe, choose Properties, and then choose Product Version.
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_user_guide_chapter09186a00805560e8.html
Hope this helps!
Rob
Re: BAT
Hi Aman,
From this good doc;
Hope this helps!
Rob
Re: BAT
Hi Rob,
Thanks for the help. My problem got resolved. After installing the BAT version 5.2(1b), I did not find option to upload /Download files. . We used CONFIGURE--->USERS--->INSERT USERS to insert *.csv file. Further, *.csv was used to update file user CONFIGURE-->USERS--->UPDATE USERS.
regds,
aman
122
