Batch import for 7916 sidecars
Is there a way to batch import BLFs for 7916 sidecars in CUCM 7.x or 8.x?  I looked at the tabs in the BAT file template and can't find anything on any of the tabs.  I also looked at Bulk Administration, but can't find anything that specifically talks about sidecars or expansion modules (unless it's under a different name).  I have a customer who will need to change the names and order of the BLFs on their (2) 24-line 7916 sidecars frequently and the manual way doesn't really allow you to shift lines up and down so I'm hoping there is a way to simply edit a CSV or XLS file and import it each time.
Bump
Bump as I'm searching for the same thing.  Have reviewed Call Manager 8.x and don't see any import/update file format that would include the desired fields to update a 7916 sidecar.  An export of all details shows the existing 7965 phone and all the programmed BLFs.  So data exports are possible but can an import be accomplished?
383
