Community Member
bcm and voice gateway integration
we  have a voice gateway and call manager system version 7 and the gateway is registered and a nortel bcm system other side ,we need to integrate this to,i did this throught the cisco voice gateway the following are the configurations
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
supplementary-service h450.12
fax protocol cisco
h323
voice-port 0/2/2
voice-port 0/2/3
mgcp fax t38 ecm
mgcp behavior g729-variants static-pt
dial-peer voice 2 voip
destination-pattern 2..
session protocol sipv2
session target ipv4:192.168.17.194
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 300 voip
destination-pattern 3..
session target ipv4:192.168.16.2
codec g711ulaw
no vad
dial-peer voice 4000 voip
destination-pattern 4..
session target ipv4:192.168.15.66
codec g711ulaw
no vad
dial-peer voice 5000 voip
destination-pattern 5..
session target ipv4:192.168.100.130
codec g711ulaw
no vad
dial-peer voice 6000 voip
destination-pattern 6..
session target ipv4:192.168.200.2
codec g711ulaw
no vad
dial-peer voice 10 voip
destination-pattern 7..
session target ipv4:192.168.200.66
codec g711ulaw
no vad
dial-peer voice 17 pots
destination-pattern 9.......
port 0/1/0
forward-digits 7
dial-peer voice 18 pots
preference 1
port 0/1/1
forward-digits 7
dial-peer voice 19 pots
preference 2
port 0/1/3
forward-digits 7
dial-peer voice 20 pots
preference 2
destination-pattern 992.......
port 0/1/0
forward-digits 9
dial-peer voice 21 pots
preference 1
port 0/1/1
forward-digits 9
dial-peer voice 22 pots
port 0/1/3
forward-digits 9
dial-peer voice 23 pots
preference 2
destination-pattern 9800.......
port 0/1/0
forward-digits 10
dial-peer voice 24 pots
port 0/1/1
forward-digits 10
dial-peer voice 25 pots
preference 1
port 0/1/3
forward-digits 10
dial-peer voice 26 pots
service autoatt
destination-pattern 4804975
port 0/2/3
dial-peer voice 28 pots
destination-pattern 77605........
port 0/0/0
forward-digits 10
dial-peer voice 29 pots
destination-pattern 77705........
port 0/0/1
forward-digits 10
dial-peer voice 30 pots
destination-pattern 77805........
port 0/0/2
forward-digits 10
dial-peer voice 31 pots
destination-pattern 77905........
forward-digits 10
dial-peer voice 32 pots
destination-pattern 7900[1-9].......
port 0/0/0
forward-digits 9
dial-peer voice 33 pots
destination-pattern 7910[1-9].......
port 0/0/1
forward-digits 9
dial-peer voice 34 pots
destination-pattern 7920[1-9].......
port 0/0/2
forward-digits 9
dial-peer voice 35 pots
destination-pattern 7930[1-9].......
port 0/0/3
forward-digits 9
dial-peer voice 1 voip
destination-pattern 480....
session target ipv4:192.168.6.8
codec g711ulaw
no vad
dial-peer voice 3 voip
preference 1
session target ipv4:192.168.6.9
codec g711ulaw
no vad
dial-peer voice 27 pots
service autoatt
port 0/1/2
dial-peer voice 5 voip
destination-pattern 1...
codec g711ulaw
no vad
dial-peer voice 4 voip
in cucm i have a route partern for the 500 series to voice gateway
the problem is from cucm i can call to bcm successfully but from bcm i cannot call to cucm it is ringing and when recieved the headset no audio between.
i also tried to created the sip trunk between cucm and bcm but no good result even in this case no call between any thing
1 REPLY
Re: bcm and voice gateway integration
Not sure what is the signaling between  Nortel--GW--CUCM
that u r using but pl. checkout following where all the interop
docs are:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/pbx/interop/notes/624995nt.pdf
http://www.cisco.com/en/US/netsol/ns728/networking_solutions_program_category_home.html
Are u using a CUBE/IPIPGW or a TDM GW between Nortel BCM and CUCM ?
1083
