Community Member
BE 6k licennsing and redundancy
Hi all,
We are planning to implement IP telephony in our network. We have 106 users. We are planning to buy 1 CUCM BE6k, 3 POE switches and a voice gateway.
What are the required licenses? we need  the basic call routing only (dont want to use video, uccx, etc.)
Is another BE6k server required for redundant SUB?
Any help will be appreciated
Thanks in advance
You'll only need CUWL
You'll only need CUWL licenses for each user.  CUCM licensing no longer cares about node count.
Another BE6k will work and you can build it out as a subscriber node or you could just use any hardware you want as long as it meets the guidelines.
Community Member
Hi Bran,Thanks for your reply
Hi Bran,
Thanks for your reply.
Can you tell me the names of the licenses we require so that we can give the order.
Purple
Hi Fayiz, you can refer the
Hi Fayiz,
you can refer the  Q & A link of BE 6K .You can get info Under Licensing Options
http://www.cisco.com/c/en/us/products/collateral/unified-communications/business-edition-6000/qa_c67-703226.html
regds,
aman
You'll want to work with a
You'll want to work with a Cisco partner to make sure you get thr right licenses for your environment.
Community Member
Hi Brian,Will the CUWL
Hi Brian,
Will the CUWL license support voicemail?
118
