BE3K VG Questions
Hi All UC Experts,
Can the VG 2921 work on the BE3000?
If it can, all functions or limited functions?
VIP Purple
BE3K VG Questions
Hi Fai,
Just refer this discussion which might help
https://supportforums.cisco.com/message/3949162#3949162
regds,
aman
BE3K VG Questions
Thanks for your reply!
Q.
Is Survivable Remote Site Telephony (SRST) available?
A. Cisco Business Edition 3000 supports limited SRST with the Cisco 2901 ISR in remote sites connected to the public switched telephone network (PSTN) using T1/E1. Please refer to the Ordering Guide for ordering information.
Is the BE3K only support the 2901? Because the 2921 is as the redundancy, which expersive is?
Need 8.6 version the BE3K support SRST?
VIP Purple
BE3K VG Questions
Hi Fai,
I think you are looking for support which is not mentioned in Q and A of BE3K.
Ideally speaking won't recommend.
regds,
aman
BE3K VG Questions
I see what you mean, but the BE3K is only support 2901 only? It is beacuse the Q&A and document just said the 2901 VG only.
160
