BE6000 call routing
We have a block of 600 DID numbers.  All have been "pre-linked" with the associated extension (last four digits of the DID).  How do we configure our BE6000HD to play a message similar to "You have reached a number that is not in service" when someone dials a DID that we have not assigned to user at this time?
Thanks in advance for your help.
Terry
1 REPLY
Create a route pattern that
Create a route pattern that acts as a catch all (XXXX).  Set this pattern to block and then you can choose the rejection reason.  You could also use a translation pattern for XXXX and then translate it to Unity Connection and have it play a message that you record.
28
