Be6000s Outbound call issue
We are facing some issue on Be6000s with cucm 11.5.1
We cannot make Outgoing GSM call.
We are using an analog GSM gateway connected to BE6000s FXO port and MGCP to control the gateway. We can receive incoming call.
we need your precious help!!
Aadhil Salim
whats the debug voip ccapi inout cause code.
Can you check the routepattern , css and partition ?
10 Replies 10
BradEast1
Level 3
Level 3
What's happening when you attempt the call? Errors, silence, etc.?
Silence and then a busy line tone
Aadhil Salim
I think routepattern, partition and css are ok: I use them with another gateway (ISR 4321) and it's worked.
find below the result of debug voip ccapi inout
002344: Nov 8 16:40:30.220: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x224CC978, Interface Type=6, Destination=044506404, Mode=0x9,
Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=044506404(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=A000000001f0bc51000000F5)
002345: Nov 8 16:40:30.220: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002346: Nov 8 16:40:30.220: :cc_get_feature_vsa malloc success
002347: Nov 8 16:40:30.220: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002348: Nov 8 16:40:30.220: cc_get_feature_vsa count is 1
002349: Nov 8 16:40:30.220: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002350: Nov 8 16:40:30.220: :FEATURE_VSA attributes are: feature_name:0,feature_time:1106411600,feature_id:114
002351: Nov 8 16:40:30.220: //114/5DCEBDFB8024/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
002352: Nov 8 16:40:30.220: //114/5DCEBDFB8024/CCAPI/ccCallSetContext:
Context=0x41BDE698
002353: Nov 8 16:40:30.220: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x223CAA64, Interface Type=9, Destination=0.0.0.0, Mode=0x9,
Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=TRUE,
002354: Nov 8 16:40:30.220: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002355: Nov 8 16:40:30.220: :cc_get_feature_vsa malloc success
002356: Nov 8 16:40:30.220: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002357: Nov 8 16:40:30.220: cc_get_feature_vsa count is 2
002358: Nov 8 16:40:30.220: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002359: Nov 8 16:40:30.220: :FEATURE_VSA attributes are: feature_name:0,feature_time:1106411376,feature_id:115
002360: Nov 8 16:40:30.220: //115/5DCEBDFB8024/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
002361: Nov 8 16:40:30.220: //115/5DCEBDFB8024/CCAPI/ccCallSetContext:
Context=0x41BDE5E8
002362: Nov 8 16:40:30.224: //115/5DCEBDFB8024/CCAPI/cc_api_call_connected:
Interface=0x223CAA64, Data Bitmask=0x0, Progress Indication=NULL(0),
Connection Handle=0
002363: Nov 8 16:40:30.224: //115/5DCEBDFB8024/CCAPI/cc_api_call_connected:
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
002364: Nov 8 16:40:30.224: //114/5DCEBDFB8024/CCAPI/cc_api_call_disconnected:
Cause Value=17, Interface=0x224CC978, Call Id=114
002365: Nov 8 16:40:30.224: //114/5DCEBDFB8024/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=17, Retry Count=0)
002366: Nov 8 16:40:30.224: //115/5DCEBDFB8024/CCAPI/ccCallDisconnect:
Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
002367: Nov 8 16:40:30.224: //115/5DCEBDFB8024/CCAPI/ccCallDisconnect:
Cause Value=47, Call Entry(Responsed=TRUE, Cause Value=47)
002368: Nov 8 16:40:30.224: //114/5DCEBDFB8024/CCAPI/ccCallDisconnect:
Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=17)
002369: Nov 8 16:40:30.224: //114/5DCEBDFB8024/CCAPI/ccCallDisconnect:
Cause Value=17, Call Entry(Responsed=TRUE, Cause Value=17)
002370: Nov 8 16:40:30.224: //114/5DCEBDFB8024/CCAPI/cc_api_get_transfer_info:
Transfer Number=NULL
002371: Nov 8 16:40:30.228: //115/5DCEBDFB8024/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x223CAA64, Tag=0x0, Call Id=115,
Call Entry(Disconnect Cause=47, Voice Class Cause Code=0, Retry Count=0)
002372: Nov 8 16:40:30.228: //115/5DCEBDFB8024/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
002373: Nov 8 16:40:30.228: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002374: Nov 8 16:40:30.228: :cc_free_feature_vsa freeing 41F27F68
002375: Nov 8 16:40:30.228: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002376: Nov 8 16:40:30.228: vsacount in free is 1
002377: Nov 8 16:40:30.228: //114/5DCEBDFB8024/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x224CC978, Tag=0x0, Call Id=114,
Call Entry(Disconnect Cause=17, Voice Class Cause Code=0, Retry Count=0)
002378: Nov 8 16:40:30.232: //114/5DCEBDFB8024/CCAPI/cc_api_call_disconnect_done:
002379: Nov 8 16:40:30.232: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002380: Nov 8 16:40:30.232: :cc_free_feature_vsa freeing 41F28048
002381: Nov 8 16:40:30.232: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002382: Nov 8 16:40:30.232: vsacount in free is 0
Context=0x41BDE698
Context=0x41BDE5E8
Connection Handle=0
hello I still have the same problem. I need your help!
sorry for the late reply. Did u find out the issue?
No sir!
Tac says it's a CSCum85086 bug.
Can you help me
Perform the workaround:
Workaround:
1) Start with reset the MGCP gateway from callmanager admin page. If issue was not so severe, it will get fixed.
2) If above is not working then next option is following:
Restart Cisco Call Manager service or reboot the server where the device is registered.
Also, deleting and re-configuring the device can solve this.
