BE6K: CUCM 10 lowavailablevirtualmemory
Getting continuous CRITICAL errors displaying in RTMT for CUCM Publisher:
": 6431: CUCM.cisco.local: Nov 03 2014 07:08:58 PM.420 UTC : %UC_RTMT-2-RTMT_ALERT: %[AlertName=LowAvailableVirtualMemory][AlertDetail= Available virtual memory below configured threshold . Configured low threshold is 25 %#012tomcat#1 (1881 MB) uses most of the memory.#012The alert is generated on Mon Nov 03 19:08:58 GMT 2014 on node 192.168.1.2.][ClusterID=][NodeID=CUCM]: RTMT Alert"
and
"Available virtual memory below configured threshold . Configured low threshold is 25 %
The alert is generated on Mon Nov 03 20:09:28 GMT 2014 on node 192.168.1.2."
CUCM Version:10.0.1.10000-24
I've tried restarting the Tomcat but didn't help.
Richard
1 REPLY
Hi Richard,You can check the
Hi Richard,
You can check the output of the following commands from the affected server to look for any warnings or core dumps:
utils diagnose test
utils core active list
If you find anything in the output of above commands its best to open a  TAC case to troubleshoot further. I would be inclined to upgrade to the 10.5 version if possible, however you need to check the compatibility details with other UC applications as well as downtime required.
Manish
248
