BE6K on 3rd Party HP server
Can I load BE6K on a 3rd party HP UC supported Vmware server?
1 ACCEPTED SOLUTION
No, a 6K is tied to a UCS TRC
No, a 6K is tied to a UCS TRC server, what you would end up would be a regular UC install on 3rd party HW.
java
if this helps, please rate
www.cisco.com/go/pdi
java
But would it work? And my
But would it work?
And my other question is do I have to buy a BE6K UCS TRC part number or will any C220 M3 server work?
Yes, from a technical point
Yes, from a technical point of view, you can use the 6K OVAs (I'm assuming it meets the HW reqs), BUT, we won't call it a 6K, nor we support it if you do that. If he HW meets the requirements from virtualization wiki, and you use OVAs approved for non 6K, or 6K AND non 6K deployments, then we would support it, but as a regular install.
If this is for a production environment, that's a huge no.
You can reach pre-sales if you're a partner, or a Cisco Gold partner for info of the current options for a 6K, but it's a bundle, HW + SW + licenses, right now we have medium density (4 app + prime) and HD (8 apps + prime), not sure about the server models we're currently selling with each.
java
I guess my main question is
I guess my main question is will i be supported if I buy a used C220 M3 that meet specs, but not the bundle part number.
Reach your SE or pre-sales
Reach your SE or pre-sales for that, I have no idea if this would be fully supported, or to what extent you would receive support for this case.
java
138
