Bearer capability not available Msg, no incoming calls
When someone calls into the office, they get disconnected. Ive done a debug ISDN q931 and here are the results:
ep 11 15:38:59.511: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x01
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Calling Party Number i = 0x2183, '7786268223'
Plan:ISDN, Type:National
Called Party Number i = 0x81, '487153'
Plan:ISDN, Type:Unknown
Sep 11 15:38:59.511: ISDN BR0/1/0 EVENT: process_rxstate: ces/callid 1/0x18 calL
Sep 11 15:38:59.511: ISDN BR0/1/0 EVENT: host_incoming_call: call_id 0x0018, Gu0
Sep 11 15:38:59.511: ISDN BR0/1/0 EVENT: UserIdle: callid 0x18 received ACCEPT_)
Sep 11 15:38:59.515: ISDN BR0/1/0 **ERROR**: accept_incoming_csm_call: modem pr8
Sep 11 15:38:59.515: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0x81
Channel ID i = 0x89
Exclusive, B1
Sep 11 15:38:59.543: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x81
Cause i = 0x80BA - Bearer capability not available
Sep 11 15:38:59.711: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x01
Sep 11 15:38:59.715: ISDN BR0/1/0 EVENT: process_rxstate: ces/callid 1/0x18 calK
Sep 11 15:38:59.715: ISDN BR0/1/0 **ERROR**: host_disconnect_ack: VOICE ERROR: 8
Sep 11 15:38:59.715: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x1
Any help would be appreciated as I cant have any incoming calls!! Incidentally sometimes I can get a dial tone when I call the office number from the mobile.. its an internal dial tone.. if I dial my extension it will connect.. HELP!!
Re: Bearer capability not available Msg, no incoming calls
hmm Looks like I needed isdn incoming voice voice to fix that. never had that in there and its worked before....
Silver
hi
issue this Cisco IOS command:
isdn incoming-voice modem
under the interface Serial0:x
and update please if this resolves or not?
774
