Best Approach: More Calling Search Spaces
Hi everyone,
In one location I have a two disctinct group of extensions (E.g. 1000-2000 and 3000-4000) that when dialling out need to go out via different ISDN lines.
Am I best off having two different calling search spaces, where one has route patterns, lists and groups that has it's ISDN line primary while the other calling search space has the other ISDN line as primary?
Everyone's tags (4)
1 ACCEPTED SOLUTION
Blue
You are almost correct.
You will have to create two route pattern for same destination, but with different partition. ANd you need to put this partition in respicitive CSS of phones.
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Blue
Ronak Patel
You can use local route group to do this. This way you will have only 1 route pattern per class
Example
Local Call for both group
RP     9.[2-9]XXXXXX --> RL --> Standard Local Route Group
DP_Group1 ---> Local Route Group = GW1-GW2-RG     (1000-2000)
DP_Group2 ---> Local Route Group = GW2-GW1-RG     (3000-4000)
GW1-GW2-RG(Top Down)
  -GW1
  -GW2
GW2-GW1-RG(Top Down)
-GW2
-GW1
257
