Bronze
Best Practice - Distribution Algorithm
Is there any type of Best Practice for which Distribution Algorithm to use for VM ports? Thanks!
Re: Best Practice - Distribution Algorithm
vm ports starting any TSP version 8.X and higher are used this way:
1, 2, 3, etc for incoming and N, N-1, N-2, etc for outgoing so match the algorithm
java
if this helps, please rate
java
www.cisco.com/go/pdi
Bronze
Is there any document stating the best practice?
i don't think i can call that a best practice, that's they way TSP works and you simply cannot change it
simply look at the integration guides for your applicable versions, they're available at CCO, look for them
java
java
Bronze
What about in the Line Group configuration that the VM ports are in?
"simply look at the integration guides for your applicable versions, they're available at CCO, look for them "
To Add Voice Mail Ports to Line Groups
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/401/integration/guide/c51acu4x.html
a little proactivity please
java
java
Bronze
I was in a pinch for a quick answer, that's why I turned to the forums. And you got me the answer. Thanks for that.
But, I wasn't looking to be lectured on being proactive.
Hall of Fame Super Red
Hey Guys,
Just thought that I would throw this in for anyone building Unity Connection 7.x
I thought the variance here was rather interesting;
(Without a Cisco Unity Connection cluster) Click Longest Idle Time.
(With a Cisco Unity Connection cluster configured) Click Top Down.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/integration/cucm_sccp/guide/cucintcucmskinny025.html#wp1109946
Hope this helps!
Rob
183
