Community Member
Best Pratice for Rolling Back 79xx Firmware
Asking for recommendations for rolling back firmware on 7940/7960(v8.0.8)on CCM 4.0.2.
Re: Best Pratice for Rolling Back 79xx Firmware
there are really no recommendations on this, get the old load in the TFTP if it's not in there and change the version phones use thru the device defaults or the device load at the device level
just remember it will take some time for the phones to get the new load and trying to get thousands of phones to do it at the same time will fail because the TFTP cannot serve them all
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
OK, thanks. I wasn't sure if I needed to remove the newer files from TFTP or leave them in place.
118
