Community Member
Best upgrade path
We are currently running CUCM, CUCCX (premium), and Unity 7.0. Our servers are going EOL in the next couple of months and we are looking to move our systems to a virtual environment and upgrade everything to 8.6. I realize we will have to switch to Unity Connection.
I was wondering if anyone could suggest the best route to go on how to get to our end result. The servers that we have now won't support any software later than 7.0. They are Cisco MCS 7825 I2's
Thanks for the advice.
Community Member
Best upgrade path
Hi Greyson,
Do you will install the 8.6 into the VMWARE environment?
Community Member
Best upgrade path
That is correct. We will be installing in VMWARE environment.
Blue
Best upgrade path
HI
1) Tahe COBRAS back of UNity
2) Install CUC in Vmware
3) Import COBRAS
Detailed steps are in below link.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/upgrade/guide/8xcucrug022.html
Ronak Patel
Please rate helpfull posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hall of Fame Super Silver
Best upgrade path
Even though version 7 is not supported in ESXi, i have been successful installing 7.X in ESXi and then upgrading to 8.X as you really have no other options with unsupported server.
As to UCON upgrade as recommaded by Ronak use COBRAS tool.
HTH,
Chris
Community Member
Best upgrade path
Chris, When you say you have been successful in installing 7.X in ESXi are you talking about CUCM or CUCCX or both?
Thanks for help.
Best upgrade path
Both.
HTH,
Chris
Community Member
Best upgrade path
Thanks for this info! I hope this works!
236
