Best way to allow call forwarding administration?
We have previously blocked the "cfwdall" option throughout the enterprise (callman and CME) but the times have changed and now they want to allow everyone to be able forward their own phones.  What is the best way to hand over the administration of these types of tasks?
Currently we do not allow users to log into the Callmanager and CME GUIs, but maybe we should?
Can users call into the system and set forwarding from the phone menu?  Thanks
  • IP Telephony
Everyone's tags (1)
2 ACCEPTED SOLUTIONS
You have to enable GUI on CME, follow the link bellow:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmegui.html#wp1056755.
"In  Cisco Unified CME 4.2(1) and later versions,  phone users can use the  web-based GUI to set up personal speed dials on  an Extension Mobility  phone. Previously, the speed-dial configuration  for a phone could only  be done in Cisco Unified CME using Cisco IOS  commands."
Rate this if helps you.
Re: Best way to allow call forwarding administration?
The access-class is to limit access on the GUI like when you apply this inside line vty configuration
To enable the GUI and Extension Mobility follow the steps:
Enable GUI
_________________________________________________________________________________________________
ip http server -->>>Enables the HTTP server on the Cisco Unified CME
router
ip http authentication local-->>> Specifies the method of authentication for the HTTP
server. local—Uses login username, password, and privilege level access combination specified in the local system configuration (by the username command).
ip http secure-server-->>> Enable HTTPS if you need
ip http path flash0:/GUI-->>> Sets the location of the HTML files used by t
web server to flash memory on the router.
Inside Telephony Service:
web admin system name administrator password !five10@! -->>> Defines username and password for a system administrator.
dn-webedit -->>> Enables the ability to add directory numbers through the web interface.
time-webedit -->>> Enables the ability to set the phone time for the Cisco Unified CME system through the web interface
After save your config and access the link http://router_ipaddress/ccme.html
Enable Extension Mobility - Inside Telephony Service
url authentication http://router_ipaddress/CCMCIP/authenticate.asp -->>> Instructs phones to send HTTP requests to the authentication server and specifies which credential to use in the requests.
url services http://router_ipaddress1/CCMIP/authenticate.asp -->>> Show the service Extension Mobility on the phone
service phone webAccess 0 -->>> Enables webAccess for IP phones
em keep-history -->>>  Specifies that Extension Mobility will keep, and
not automatically clear, call histories when users log out from Extension Mobility phones.
em logout time xxxx -->>> Defines up to three time-of-day timers for
automatically logging out all Extension Mobility users
Inside Configure Terminal
Create the logout profile -->>>To create a logout profile to define the default appearance for a Cisco Unified IP phone that is enabled for Extension Mobility, perform the following steps
voice logout-profile 1
pin 12345
user logout password logout
Associate this logout profile with the ephone
ephone 1
logout profile 1
Now you will create the login profile and the Directory numbers
voice user-profile 1
pin 12345
user lukeprimm password 12345
number 555 type normal
ephone-dn  1  dual-line
number 555
label lukeprimm
name lukeprimm
Now you can log on the phones, in this example that i gave is for SCCP Phones, for SIP phones is a little different take a look on CME  Version X.X Admin Documentation.
Luke you can associate the ip phone/directory number with a end user, and them the user can access the configuration of his phone trough the link.
https://X.X.X.X:8443/ccmuser
And after that the user can set the destination of the Call Forward and other configurations like speed-dials.The users will have only access to their ip phone configuration not to the CUCM configuration.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080b3dd05.shtml
Regards.
Thanks, and if the files arent on the router to allow for GUI access, what do I need to do to enable this feature?  Thanks
Oh sorry do you have CME, let me do a quick research and i will answer you.....
yes, we have 5 CME installations and 1 CM cluster (though the cluster is fine, its accessible) just the CME's are not accessible via the user GUI thanks
great, thanks
YOu have to enable GUI, and the EM for the users.
Tks
THnaks, what is the EM?
Extension Mobility, permit the users to log on their phones. They will a logon profile with their configurations.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemobl.html
Rgds
658
