Beware - 729br8 with MGCP on 12.4(24)T, no way / one way audio
Hi All,
If your gateway is MGCP and your service parameter to advertise G.729 annex-b, which is the default, you will not be able to hear audio on 12.4(24)T.
Becoming kind of a hot bug, thought I would let you know.
Details:
CSCsy10653
Symptom:
Calls on an MGCP gateway negotiating g729br8 may fail to have audio in one or both directions.
Conditions:
This occurs on MGCP gateways with the fix for CSCsu66759 when g729br8 is being negotiated.
Workaround:
Any of the following will be sufficient to get around this issue:
1. Configure the gateway for static payload type using the following commands on the gateway:
mgcp behavior g729-variants static-pt
mgcp behavior dynamically-change-codec-pt disable
2. Disable g729br8 from being negotiated for this call. If CUCM is involved, this is done with the service parameter 'Strip G.729 Annex B (Silence Suppression) from Capabilities'
3. Downgrade to IOS code on the gateway which does not contain the fix for CSCsu66759, which would be 12.4(22)T and below.
hth,
nick
Re: Beware - 729br8 with MGCP on 12.4(24)T, no way / one way aud
Thanks Nick,
Saved me hours of frustration and a TAC case.
FYI, Upgraded to 12.4(22)T2 per the "Fixed-In" comments and it did the exact same thing, still required the two mgcp behavior lines to have audio.
So in 12.4(22)T2 it is NOT fixed yet.
Frank
399
