Billing System for CCM 5.X
I'm looking for a billing system with one specific feature.
I need it to move a phone to a different calling search space after reaching a certain minutes of talk time.
Anybody has any idea of an automated solution like this?
Hall of Fame Super Silver
Re: Billing System for CCM 5.X
You mean CallManager Calling Search Space? All billing systems are read only, they can not modify CM database, so this can not be donw without some customer AXL development.
Chris
i don't believe there is anything to do what you want, billing systems only get the CDR records and that's it. they don't perform changes into the system. they don't even access the system, you configure them as billing servers under CDR config and push the information via FTP or SFTP to them.
best guess is that as Chris mentions you'll need to write down an AXL custom application if you really want this cuz nothing out there has this
java
if this helps, please rate
java
www.cisco.com/go/pdi
105
