Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
billing systems CCM
What is the billing system for CCM7.
2 ACCEPTED SOLUTIONS
Re: billing systems CCM
ISI Infortel solution is the one I use the most it is solid and they have been a long time partner with Cisco.
Hall of Fame Super Red
Hey Slava,
Hope all is well!
The Cisco Partner program has a number of tested solutions for Billing/Accounting (CDR) products. Here is the link;
http://forums.cisco.com/eforum/servlet/IPCApps?page=Call_Acct_Billing
Hope this helps!
Rob
if you mean if we include a billing system with CCM we don't. we only provide CAR with the limited functionality it has.
you're free to look into the partner locator for billing systems compatible with your version since you do not mention what you have
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hi. Wi have Cisco Call Manager 7.
Hey Slava,
Hope all is well!
Hope this helps!
Rob
thanks for you help.
Slava,
You are always welcome my friend!
Rob
196
