Bind an extension to an external number
Hi!
I'd like to know how I could bind an extension to an external number ?
If someone dials extension 12345 from his IP Phone, then the call is transfered transparently to landline 1-514-555-9876
Thanks !
Re: Bind an extension to an external number
You can do this really easy, just use the Call Forward All on the extension to the landline. Make sure to use the exact pattern that you use to call that number for example, 95145559876 if you use 9 to dial out.
Wow, that was indeed very easy. thanks a lot. 5 stars :)
Can this also be done remotely?
you would need to do this thru the CCMUser page if you want to set the CFA manually remotely
that is the only other way to set it if not from CCMAdmin or from the phone itself
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
123
