Black list on phone
Is it possible to create personal black on particular phone?
Hall of Fame Super Gold
Re: Black list on phone
Yes, you can configure a cor list, a translation with reject... there are multiple ways.
Can I do this without CUCM help, if I use MGCP gateway?
Also , can I do this for PERSONAL phone without changing CSS,Partition,DP on Phone?
Sorry, I tought it was a CME question.
You cannot do anything with numbers at GW level if using MGCP.
Just to add to the great info from Paolo this config is based on ANI so ANY call will be blocked they're not personal.
only H323 or SIP, no way with MGCP
please use the search NetPro options this has been asked hundreds of times before
java
if this helps, please rate
java
www.cisco.com/go/pdi
270
