Community Member
Blank CME html page
I know this question has been posted before but I have not seen a solution.
When I launch http://x.x.x.x/ccme.html I get the login box. After I enter the credentials, I get a blank page.
I have put in ip http server and ip http path flash: in the configuration but still a blank page. Does anyone have a solution?
1 ACCEPTED SOLUTION
Blank CME html page
Hey there,
Add this command:
config t
file privilege 0 (hidden command)
exit
This is stated in the Readme that comes with CME package (8.8).
John
Community Member
Re: Blank CME html page
Hello bimckenz,
It very well could be that some files of the GUI are either missing or corrupted.
Could you please send your current configuration with a show ver, show telephony-service, if the configuration is fine we could have a look at and as a last resort
re-copy the files to the flash, during this process it is vital to not have any packet loss.
It is ideal that we make sure that you have also the proper version of the GUI, if you could tell me which tar file you downloaded maybe we can find to which CME version it corresponds to make sure that we have the proper GUI version.
Community Member
Hello
I have the same problem. Do you know how fix it?
Community Member
Look for a gui folder and point your http path to it.  I created a folder for all the telephony files called "phone" directly on flash:, so I had to enter "ip http path flash:phone/gui" to get it to work.  If you extracted your files directly to flash, I'm guessing it would look like this "ip http path flash:gui".  BTW, this is on a 2951 router running 15.0(1r)M1.
Blank CME html page
Hi all, As Scott said all you have to do is point to where your gui files are:
ip http path flash:/gui
Jorge
Community Member
Hi Bimckenz
check if you have the files for GUI and the follwing  commands
commands (global config)
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:
files in the flash:
    admin_user.js
      admin_user.html
     dom.js
   normal_user.html
    normal_user.js
telephony-service
web admin system name XXXX password XXXX
dn-webedit
time-webedit
Blank CME html page
Hey there,
Add this command:
config t
exit
John
Community Member
adding the command  "file
adding the command  "file privilege 0" fixed that for me
Community Member
I have similar issue with
I have similar issue with C2911 router. After I added file privilege 0, I was not even able to login. I removed command and not I am not able login even.
Community Member
I've got a 2801 with the same
I've got a 2801 with the same problem, but doesn't recognize the "file privilege 0" command.  I'm running 15.1(1)T code.
Community Member
Thanks,by adding file
by adding file privilege 0
it works....
3742
