BLF and Speed Dial on CCM5
I'm searching the way to configure BLF and Speed Dial from the ccmuser with the CCMV5. Is it possible ? If yes, how can I do ?
Thanks for your help
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: BLF and Speed Dial on CCM5
Hi Gadacha,
BLF/Speeddials can only be configured by the Admin :(
Hope this helps!
Rob
Gold
Yes, this is possible. Here is the link which gives details about how to configure it http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/5_0/sys_ad/5_0_4/ccmfeat/fsprsnc.htm#wp1109780
Dear all,
under 5.0 (2000.1) was supported less 14 BLF on 7914, upgrade to 5.04(2130)which will solve it.
enable presence to allow (default restrict)
& change CCS to allow all.
Thanks, but the question is:
Is it opssible for a user to configure their own speed dials and BLF from the ccmuser (not the ccmadmin) ?
Hi Gadacha,
Hope this helps!
Rob
152
