04-03-2008 05:17 AM - edited 03-15-2019 09:49 AM
Can a BLF be setup to only indicate the monitored DN is off hook via the icon on the screen and disable the lamp?
04-03-2008 11:03 PM
I dont think we have that option..I wasnt able to see any options under Service Parameters. Is there any reason why you want to disable the Light?
I dont think that without the light the notification can be really noticed by the users
04-04-2008 03:58 AM
User says it is "distracting" is the reason.
