BLF not working
We have CM 5.0 When we configure the phone button templete and bury it to 7961, it doesn't work. When the configured numbers are busy, the BLF signal doesn't light up. Is there any trick?
Bronze
Re: BLF not working
I was trying to get BLF working the other day with a 7941 watching the status of a 7940 on call manager 5.1.2 and could not get it to work that day but got busy so I believe I need to know if there is a trick to get it to work as well.
Bronze
Re: BLF not working
Assuming that you are using the correct phone template for BLF and the device is configured for BLF, make sure that the SUBSCRIBE CSS is set on the device you are trying to see the BLF on.
Use a common CSS for the SUBSCRIBE CSS or one that will be searchable by all DN's.
Thank you,
Jon
Re: BLF not working
Hi Guys,
I am trying configure BLF in CUCM 8.6.2 and I am having the same problem.
First I created the new phone button template
Then did associate with the speed dial line to BLF
Then Apply the new phone button template and the two DN´s
Then apply css in subscribe both ip phone
then restart two phones, but, didn´t worked
Any have idea about this?
Wilson
Re: BLF not working
Hi Wilson,
Please double check the SUBSCRIBE CSS on the phone page for access to all lines. CM ADMIN--DEVICE--PHONE
That particular CSS needs to reach the partition of the phone being monitored, after that reset the phone
Configuration Checklist for Presence
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_5_1/ccmfeat/fsprsnc.html#wpxref
34263
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
Re: BLF not working
Hi Nadeem,
I am sorry by delay in answer, I did the configuration and worked. Thanks a lot for you attentation
Wilson
Re: BLF not working
Np wilson, good to know issue sloved.
Br,
Nadeem
668
