BLF/Speed Dial is not working
Here is the steps I followed
  • Enable the BLF for Call Lists (enterprise parameter).
  • Allow subscriptions for presence cluster wide (service parameter)
  • Configure phone button templates using speed dial BLF.
  • Assign templates to phones.
  • Add BLF speed dials to phones.
  • All the phones are in PT- Internal and CSS-HQ
  • Reset CCM service and phones
CUCM version 7.1.3-10000-11
IP Phone- 7961 and also tried on 7945 same results
BLF does not work but speed dial is working! what am I missing here
Thanks for your help in advance
1 ACCEPTED SOLUTION
Re: BLF/Speed Dial is not working
Check the configuration of the Device...
Go to "Protocol Specific Information" and under SUBSCRIBE Calling Search Space you need set a valid CSS to reach "Internal" number
Hope this help!
Alberto
Bronze
have you checked that that Subscribe Calling Search Space on the phone or user is set and has the required access?
Paul
Thanks Paul
I did try putting the CSS on the user (I have css on the phone which has access to all partitions)  which I didnot configure before and reset the phones but no change in BLF! still BLF is not woking!!
Hope this help!
Alberto
Hi.. It worked from me as well. But for me since I had extension mobility, I had to select the BLF presence Group under UserManagemet ---> end user. Also I had to select an appropriate value for SUBSCRIBE Calling Search Space in the End user page.
Bejoy Thomas
this corrected my issue on
this corrected my issue on the 8851 models as well - forgot about this drop down option. Thanks for posting it.
Bingo
Its working
Appreciated your help
Bingo from me, too!!!
ya the man!!
That worked, thank you.
5200
