Community Member
BLF stopped showing activity status
I have two different locations having this same issue. The BLF key will stop showing the status of the other but, after a reset of the effected device it works.... only to have the problem roll to another phone in that same call pick up group. The BLFs work as speed dials. Only the flashing to show status has stopped. If the user unplugs the phone or if we perform a RESET of the phone, the flashing returns. It continues to roll through the entire group.
What registration is upon the reboot/restart of these devices? How do I isolate this problem?
What model phones/protocol
What model phones/protocol and firmware version?
Community Member
All devices involved are
All devices involved are 7965s, SCCP, 45.9-0-3S
The sidecars that are involved would be 7916 v2.
There's a few bugs like that
There's a few bugs like that on the SIP firmware but shouldn't apply to the SCCP firmware.  9.0(3) is pretty old.  Can you try upgrading one phone to a later firmware version and see if that resolves the issue?
If not, we'll probably need CallManager traces/packet captures covering the period of going from working to nonworking to figure it out.
Community Member
Can you walk me through the
Can you walk me through the firmware upgrade or how to find/capture a trace file?  These events are transient and once reset, they may stay clear for hours or days.  We have not found any patterns with which we can predict these occurances.  Your help is appreciated.
Community Member
Nevermind.  I know how to do
Nevermind.  I know how to do that.  I don't know what I was thinking.  I will try it out and post results.  Thanks!!
Community Member
How many phones are in the
How many phones are in the cluster? Try restarting the CTI Manager.
Community Member
The cluster has almost 8,000
The cluster has almost 8,000 phones.....
Community Member
Strictly CUCM. I am going to
Strictly CUCM.
I am going to perform a localized upgrade to the firmware of the phone and monitor.
I will post results.
CTIManager is not used for
CTIManager is not used for local BLFs.
Community Member
8000 phones means that there
8000 phones means that there is probably more than a CUCM. CUPS, a switchboard, shared lines, Lync or Jabber,... all subscribe to the status. A short network outage or a failover of many phones can cause problems. We observed this many times in the past years. Sometimes lines are busy but no one is using the line, after a reset everything works normal an a few days another line is affected. A phone is ringing and as soon as you lift the receiver the other party is put on hold. ...
A restart of all CTI Manager services solved the problem, otherwise reboot the cluster.
