Blind transfer
Do we have any specific parameters to be setup in CUCM for blind transfer to be enabled from Cisco hard phones (for transferring to SIP based external PSTN users). (SCCP phones in CUCM uses an annunciator software device that is often located with an MTP device)
Issue: Transfer key does not appear on phone until the RBT comes from other end.
Blind transfer
The one thing to check is to see if the Transfer key is present in the Softkey template, second thing is to check if you have a Conference bridge in your device's MRGL.
Please rate useful posts.
Blind transfer
Point is Transfer softkey does not appear until ring back comes from other end- even though DSP resources are there.
Is this a tested feature from Cisco
Blind transfer
change the service parameter
Transfer On-hook Enabled to True
This will allow users to hit the transfer softkey and dial the number and either go on-hook or hit the transfer softkey again to complete the call
Blind transfer
As far as I know, remote end needs to send atleast a response (progress/connect) for the transfer key to show up. Will have to see if anyone else has other ideas.
Blind transfer
I agree with George, just as you cannot transfer a call unless you pick it up, you cannot transfer a call which the system doesn't know "might" connect, and that's via the messages from telco.
Once the call has progressed up to the point on which you get ring back, THEN, you can transfer the call, not before.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Blind transfer
Hi all,
say it was un-normal, then is it possible to make it appears when we call someone and during ring out without the remote end answer the call, i have a customer which asked it.
ahmad
333
