Block 1 number
mwild
Is there a way to block just one number coming in. for example a telemarketer that calls me everyday?
thanks
6 Replies 6
Brandon Buffin
One way to do this is with a translation rule on an h.323 gateway. Take a look at the following link.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml#con13
Hope this helps. If so, please rate the post.
Brandon
anyway using MGCP or within CCM itself?
thanks
With MGCP or CCM itself it is impossible.
With MGCP or CCM itself it is impossible.?
Please explain
CCM itself doesn't have built-in feature to
analyze caller-id of incoming call, e.g.
MGCP, protocol of CCM side is the same thing.
There is no way that I'm aware of to do this with an MGCP gateway.
Brandon
