Block a specific phone number using CUCM
How do i block a specific incoming phone number from calling into the CUCM systes.
Thank your for your help.
Hall of Fame Super Silver
This has been asked many times here and you should be able to search for options. Basically there are 2:
if using H323/SIP for GW control use translation-rule reject on the GW
Or use "Route Next Hop By Calling Party Number" feature on CUCM translation pattern if you have CUCM 8+ (I think).
HTH,
Chris
Hi Jeff,
you can also use the ECC (External Call Control) to achive your needs.
For this, you have to have some external app which will handle it.
2Ring PHONE SERVICES (http://www.2ring.com/NewJuice) may be the one what you look for.
By the way, FREE or TRIAL license is obviously available.
Martin
HI Jeff,
The requiremen to block selected incomming/Outgoing calls to CUCM can be achieved using MARS Intellicall Application for CUCM ( based on CUCM CURRI)
Application video : http://www.youtube.com/watch?v=k_dqcQ6prhs
Doc: http://www.slideshare.net/pranjol/parsecs-intellicall-application
233
