04-03-2008 11:53 AM - edited 03-15-2019 09:50 AM
Is there a way to block called name / number from being sent out an mgcp gw on a per phone/line basis?
thanks
Solved! Go to Solution.
04-03-2008 12:31 PM
unfortunately with MGCP that can only be set at the route pattern or translation pattern level.
you could create a RP for the phones you want to block so they use it.
javalenc
if this helps, please rate
04-03-2008 12:31 PM
javalenc
04-03-2008 12:33 PM
yes, thats what I thought. thanks for the sanity check
