08-29-2008 06:48 AM - edited 03-15-2019 12:56 PM
We have a voip infrastructure based on CCM 4.2 and a small call center. We have a problem with a caller who is bothering the CC collegues and I want to block his calls. Is there a way to block calls if I know from what number he's calling or to forward his calls to an unused DN so he will receive a busy tone?
Marian C
08-29-2008 06:49 AM
if uhave h323 it is possible it not
i think not possible unless some one know somthing very new to CCM
in CCM u can only based on called numberon h323 gateway u cam match based on called or calling
08-29-2008 06:58 AM
Only possible with H323, this has been asked previously tens of times, please try using the search function within NetPro to look previous posts
Reject Calls
Call Blocking Configuration Examples
java
if this helps, please rate
08-29-2008 06:57 AM
Is this a MGCP gateway or H323?
08-31-2008 09:50 PM
it is an mgcp gateway
08-31-2008 09:54 PM
unfortunatly with MGCP u cant make matching based on ANI calling number
so u cant block that call
good luck
if hlepful Rate
08-31-2008 11:18 PM
really?
09-01-2008 07:26 AM
yes, seems you haven't gone thru the docs i posted, since they state it's ONLY for H323
MGCP CANNOT DO THIS; THERE IS NO WAY TO DO THIS WITH MGCP; ONLY H323 CAN DO THIS
java
