01-28-2010 01:41 PM - edited 03-15-2019 09:13 PM
I am trying to block an inbound call from a particular phone number to a particular phone.
I am using call manager 7.1.2.
I know how to do this in the call center world using express or enterprise but I do not know how to do this with ONLY call manager and the voice gateway.
Scenerio:
Caller calling from cell phone 555-1111 to a phone inside my company 317-1111. I want to prevent 555-1111 from reaching 317-1111.
Solved! Go to Solution.
01-28-2010 01:43 PM
This is only possible if you're using h.323 on your gateway. It will not work with MGCP. See the following link.
https://supportforums.cisco.com/docs/DOC-1850;jsessionid=4231E90CE9E92C2370C5A7E84254EC03.node0
Hope this helps.
Brandon
01-28-2010 01:43 PM
Hope this helps.
Brandon
01-28-2010 02:00 PM
Well poo!
Thanks for the info though!
Del
