Community Member
Block incoming call on 7941 phone
Is there a way where I can a block an incoming call from a specific number on only one 7941 phone?
Any Suggestions..
What you're asking has absolutely nothing to do with the endpoint model, there are hundreds and hundreds of posts on CSC on how to block incoming calls, in H323 for all versions, and with MGCP on some CUCM version.
Do a quick search and you'll get all the necessary info.
Also, if asking for assistance, you always need to mention what you're working with, not just what you want, the answer depends completely on that.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Community Member
Hi Jaime,
We are using Call Manager Version 8 MGCP and I wanted an incoming call from one certain number to be block when it calls only one 7941 phone in my network, how can this be accomplish?
Hi ,
you can block all the call coming from that particular number.
you can accomplished by checking the CLI using translation pattern on dial peer from gateway..
Please refer the below link : https://supportforums.cisco.com/docs/DOC-19628
Please rate the post if it help.
Shalid K C
Silver
Re:Block incoming call on 7941 phone
You need to search on ( partitions and calling search space ). You will make use of that and its easy to deploy in callmanager.
Sent from Cisco Technical Support Android App
364
