Block incoming numbers on gateway
Hi all
Can anyone advise if there is a way to block unwanted calls coming into our gateway. I have done this on a H323 GW using a translation rule and explicit  "block this number" . We are running MGCP on this box and using CUCM 6.1.4
Any ideas??
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Block incoming numbers on gateway
Hey Simon,
This type of Call Blocking is still not supported with MGCP
These documents were nicely posted up by Java recently;
Call Blocking Configuration Examples
http://www.cisco.com/en/US/customer/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml#con11
Reject Calls
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml#reject
Cheers!
Rob
Hall of Fame Super Gold
This is asked frequently and you would find the answer with a simple search.
There is no way to do that with MGCP.
Hey Simon,
Reject Calls
Cheers!
Rob
Thanks Rob
I did not think there were any changes to the rule
Have a good weekend
Simon
203
