Block internal calls CUCM
Hi.
i hope you can help me with this requirement.
I want to block the calls between Ext 1000 and Ext 2000 only in that side, i mean that the ext 2000 can call to ext 1000.
I want this because ext 1000 belongs to a secretary and de 2000 to president, exist other secretaries and they must call to that extension (2000)
Thanks.
CSS and partitions, configure
CSS and partitions, configure as required.
java
if this helps, please rate
www.cisco.com/go/pdi
Exist another way ? because
Exist another way ? because only want to block that call, and not the all CSS of secretaries.
No, you'll need to adjust as
No, you'll need to adjust as necessary for that, new CSS, new partition, or change existing elements as necessary, but if it's only for one DN, it'll need a separate partition.
java
212
