Community Member
Block internal calls on CME
Is there anyway to block internal calls on CME?
For example, phone 1000 no call to phone 1001 in same Router.
1 ACCEPTED SOLUTION
Yes , i have already shared with u all links for COR and i provided u with two solution one for COR and other for after hours.
Thank you
Please rate all useful information
Re: Block internal calls on CME
You can do it by using COR , Please find the below link:-
http://www.cisco.com/image/gif/paws/42720/configuring-cor.pdf
http://www.hh.se/download/18.70cf2e49129168da015800092952/4_11_Class_of_Restriction.pdf
Thank you
I have configured below some solutions , i hope all help you:-
1-
voice translation-rule 1
rule 1 reject /1000/
voice translation-profile REJECT
translate calling 1
Then go to the ephone-dn (which has number 1001) . The below configuration based on your IOS.
ephone-dn  50
     number 1001
     translation-profile incoming REJECT
or
ephone-dn  50
     number 1001
     translate calling REJECT
2-
telephony-serv
  after-hours block pattern 1 1000  7-24
Then under ephone with DN other than 1001 configure  after-hours exempt CLI.This will block only 1001 , when you enable after-hours exempt under other phones this will allow other phones calls 1000.
Thank you
Please rate all useful informaion
Community Member
Hi Islam,
Some solutions with COR ?
Thanks.
Thank you
Community Member
Islam
242
